Incin Posted August 17, 2010 Report Posted August 17, 2010 Alright my amp stopped turning on awhile ago so I replaced all the fuses with new ones and still nothing. I just got my new amp today and still nothing, I just bought new cables and put the new power and ground wire in but yet still nothing so i came to the conclusion that my ground location went bad or I need to put my new remote wire in or change the RCA cables with the new ones. What do you guys think I should do first? well, it'll make you shit bricks.
55437Audio Posted August 17, 2010 Report Posted August 17, 2010 Check remote make sure you get the ignition power then maybe check your ground spot make sure it's an actual ground spot. Then if no luck make sure your amp is even getting power. Let us know if those don't work My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
MrSkippyJ Posted August 17, 2010 Report Posted August 17, 2010 you could check wires to make sure they are getting power with a meter instead of changing one wire at a time. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
55437Audio Posted August 17, 2010 Report Posted August 17, 2010 Yupp a dmm or digital multi meter from like walmart or some auto store is what you want My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
mikeg321 Posted August 17, 2010 Report Posted August 17, 2010 Sounds like a remote lead problem. Try hooking a short wire to the remote input on your amp then touching that wire to the B+ terminal on your amp. if the amp turns on your remote lead is the problem. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Incin Posted August 17, 2010 Author Report Posted August 17, 2010 Alright, thanks guys Ill do all that in the morning. Ill just run the new remote wire that I got with the pack of wires from wally world well, it'll make you shit bricks.
Incin Posted August 17, 2010 Author Report Posted August 17, 2010 Also do you think the remote wire could have came undone from the deck itself? well, it'll make you shit bricks.
mikeg321 Posted August 17, 2010 Report Posted August 17, 2010 Also do you think the remote wire could have came undone from the deck itself? It could have come undone or it could have shorted out. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
