Vibration reducer for amp
What can I put under the feet of my amp to stop the vibration getting to the amp from my box? I plan on going to home depot tomorrow and was just wondering that I need to pick up.
i'd go with some rubber grommets or something soft rubber like (no condom jokes lol)
Well, you wont really get rid of it all together but if you feel there's to much vibration going on I use to use the rubber seals you use for sinks, toilets etc also lets air flow through under the amp to help cooling. Had a friend use some shock absorbers from his PSE Baby G compound bow haha. Worked fairly well. Easier to mount your amp elsewhere though if you think it's going to cause harm.
I'm not an out of control driver, I'm completely in control.. only sideways..
-Nissan R32GTR running 213KW RB20DET on 14lbs of boost.
-Holden Commodore VY SS UTE running stock.
-Holden Rodeo mini truck project, soon to be running SR20 on 13lbs of boost.
-Landcruiser UTE running 1UZFE v8 11" Lift on 35" MT Classic II's wrapped in Cooper STTs.
^^ and the list goes on..
mount to the side of the enclosure like the rest of the smart ones.. jk
but yeah krannys right
some soft rubber haha
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
i used some washers that had a small rubber piece to one side and metal side to the other. heres a pic of the screws they come on. i took the washer piece off and used a smaller screw. IT WORKED FOR GREAT!
bad ass man whered you get that? Ill have to take a look around my hardware store a little longer
ty
TY
yep.....:)
lowes i think, i got the at work...but what i did was put the washer with the rubber side towards the amp between it and the box, the the the screw goes in.
yeah well i would probably be doin the same. only need the washer, that looks like a self taping screw or somethin, dont need that. but that washer is pretty cool
TY
yep.....:)
  • Who's Online   0 Members, 0 Anonymous, 2593 Guests (See full list)
