1000RMS for 2 12"s.
The amp is 1000rms @ 2ohms, 1350w@ 1 ohm
so to figure this out, you take the total wattage * ohm load, then find the square root of that.
1000 * 1 = 1000
the square root of 1000 = 31.62. you could wire down to 1 ohm and using a DMM, set the gain to 31.62 volts AC
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I know how to set them not to clip with a DMM.. but how do I do the wattage? Just keep the voltage down to what it matches to?
How do you know how to do that, but not voltage?
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
More than likely the same way people think using a DMM stops clipping...
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Nah, I know it's not COMPLETELY accurate and all.. The only true way is with an oscope and all. And because I was told my voltage limits, I didn't know about the big chart thing until just a while ago. :P
