Using a fuse for your alt wire??
Hello all,
I have seen several vids of meade's designs on his engines with all the alts and i was wondering... Why would you use a fuse to protect the alternator and the batt? Wouldnt you want to get a ton of power from your alt and not blow a fuse doing it??
And plus, if anybody knows someone who builds brackets for alternators please please hit me up, im going to buy an alt for a 1998 oldsmobile 88 (my current car i drive) and i want to be able to put that same 300 amp alt into my dads 1997 chevy tahoe when i buy it. yes i know that they arent bolted in the same way which sucks but i was wondering if anybody knew some guys who can make me a custom bracket where i can strap the alt of my oldsmobile into the tahoe as a secondary alt.
Thanks in advance!!!
you put a fuse in line with the batt and alt. so if you hook anything up wrong or short something out, the fuse blows and saves all of your electrical. and possibly your ride.
Edited by ugpbmx
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
you put a fuse in line with the batt and alt. so if you hook anything up wrong or short something out, the fuse blows and save all of your electrical. and possibly your ride.
thank u for typing that for me
1) lookj to left
2) NOTICE BLKUE
3) ME > Y9OU
4) that is all
thats what i was thinking but i never saw the point since stock alts never have a fused positive wire. Not that it makes any difference but should i use a mini-anl fuse for the alts wire or a normal anl style fuse? i have the room for both types so its not a big deal for it.
normally a stock alt on stock electrical will run through some type of fused link, somewhere in the cars electrical system . i would use a normal sized anl fuse.
i didnt fuse my 1/0 wire from my alt... but i did use 1/0 wire loom and ziptied everything up
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Hello all,
i relation to your alternator swapping idea i believe don't quote me here but i think iraggi alternator has a plan that can be purchased that will allow you to order one H/O alt for your 88 then when you change vehicles you can send it in for one that is made for the tahoe. like i said i think this is true pm iraggi to find out.
1995 Honda Accord Coupe
still building only thing done is big three and one run of stinger 0 gauge.
Feedback
yea the fuse is there just for safety, you don't have to use one. just make sure you use the appropriate gauge wire so it doesn't melt when you start ur car lol
i already have a ton of 1/0 from my co-worker. i also have 1/0 for the amp and everything.
  • Who's Online   0 Members, 0 Anonymous, 1832 Guests (See full list)
