need help with new system in my blazer
go for a lvl 4 on about 1500
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
^^^^ nice build kanes. How are you liking those p3's? when you put the sound deadener on your roof did that make a good difference. Im looking at ways to stop roof flex later when i get my new subs in. just wondering if the deadener helped any on the flex
2001 GMC Jimmy SLE 4X4 Floor Shift AutoHeadunit - Alpine CDA-117Front Door Speakers - Alpine SPS-600C MidsRear Door Speakers - NoneDash Speakers - Alpine SPS-600C TweetersSub Amp - Rockford Fosgate T4002Mids+Highs Amp - Rockford Fosgate P4004Subwoofer - P3D215 Fosgate Punch 15Sub Box - Rockford Fosgate designed "powerful" ported box Built by myself
i would rather run cheaper but sexier then expensive and fucking ugly.
I am really liking the P3's, they are plenty loud. As far as the sound deadener goes I do gotta say it has helped with the flex in my roof and it is a cost efficient way to help out. I bought mine at home depot for $21 a roll and I used 2 and a half rolls on my roof and tailgate. I found out that my amp is putting out almost 1,200 watts and the P3's can take every bit of the amp at full tilt and I haven't blown them yet! I hope this helps you!
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
width-38.5, tall-17,depth-24 (port-14.5in tall, 5in wide,18in long) Thats a great box for 2 15s, ive done many test with boxes in blazers this turned out to be a good one. Its below the window line and matches perfect with the back seats, so you would be great in comp classes.
Head unit-Clarion
Mids & Highs- Oxygen Audio 5.25's
Highs Amp-ASA-600.4x
Subs- 3 15in American Bass XFL's
Sub Amps- American Bass VFL 500.1
Im not sure on what amp ill be using yet but i know ill be getting a set of loaded 15" Fi SSD subs
how would you suggest running 1/0 to the back of my blazer? I think i might be having to do 2 runs of 1/0 do you think? if im running maybe two 1800 watt amps?
I ran my 0 gauge from the passenger side over to the drivers side and drilled a hole in the firewall up close to the brake master thingy lol. Then I ran down the drivers side by the door jam and went underneath the back carpet and toward the middle of the seat. I do know once I was done I couldnt get my trim pieces back down on my floor because of the wire being so thick. I would have went underneath the carpet all the way to the back but I have heat vents that go under both of my front seats, so there was no way to run the 0 gauge wire that way. I hope this helps you!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
  • Who's Online   1 Member, 0 Anonymous, 1673 Guests (See full list)
