A four door blazer has the following dimensions. Roughly. 38 x 30 x 25 including seat lean. The depth shrink quickly after 17 high due to the angle of the rear glass. if you at or bellow 17 you have as much as 35 deep. Ie.38w x 17h x 35d
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
^^this man is correct lol. Are you dead set on Rockford?? I would check out the SA-12s. The results have been proven on how beefy these woofers are. Or do something like 8 8s...that would be awsome
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
^ 8 8's ftw. I have ones 2second gen blazes lol both four doors. ;)
Subs: 2 T1 12's
a single btl would require you to upgrade your alternator which would cost you some money.
Why would the type of sub require stiffer electrical? Of course the BTL has a higher rms but that does not mean he needs to run it at higher power. And a new alternator for 2000 isn't required in my opinion.
To the OP, BTLs are beasts for sure but if you can do two 18s do it. More cone area and closer to your budget.
im thinking either 2 fi ssd 15's fully loaded or 2 fi q 15's with extra spider and p chamber
2001 GMC Jimmy SLE 4X4 Floor Shift AutoHeadunit - Alpine CDA-117Front Door Speakers - Alpine SPS-600C MidsRear Door Speakers - NoneDash Speakers - Alpine SPS-600C TweetersSub Amp - Rockford Fosgate T4002Mids+Highs Amp - Rockford Fosgate P4004Subwoofer - P3D215 Fosgate Punch 15Sub Box - Rockford Fosgate designed "powerful" ported box Built by myself
i would rather run cheaper but sexier then expensive and fucking ugly.
Subs: 2 T1 12's
18's are beasts.
Subs: 2 T1 12's
