nomanaserilanco Posted August 26, 2010 Report Posted August 26, 2010 ok well the main reason for this post is just a question i wanted to ask before i put a bunch of possibly useless work into my system. which would be louder 1 12 running at 2 ohm or 2 12 at 4 ohm and now i know thats to general and you guys will wana know more details so i currently have 1 12" rockford fosgate dvc from about the 90's im not sure exactly but it is a dual 4 and it is 400w rms and 800w max and i recently found another that i could get for 20 bucks thanks to craigslist and i was wondering if it would be louder if i hooked up both. my amp is an infinity 611a mono block which according to the manual is 650w rms at 2 ohm and 450w rms at 4 ohm and i currently have it just hooked up to one another question i had was what is the best frequency to tune a box to if you want good loud low bass but you also want to have it not drop of a great bit in the higher bass. i currently have it tuned to 30hz and i like the way it sounds on songs like put on that his really low but i wish it had more in the upper end but a sealed box doesnt have enough volume for me. thanks for the help guys
nomanaserilanco Posted August 27, 2010 Author Report Posted August 27, 2010 idk exactly how this works but i think i remember that you can "bump" your topic so it is in recent topics every once and a while so bump
nitro229 Posted August 27, 2010 Report Posted August 27, 2010 Why can't you get the other and wire down to 2 ohms? Or 1 ohm? An if you drop the power but add another sub I would think it would kinda be the same loudness, but why not get both an then upgrade amps? And try 32 hrts box! I'm not an expert at all but thats what I would do
Robert8252 Posted August 27, 2010 Report Posted August 27, 2010 2 Dual 4 ohm can only be ran at 1ohm or 4ohm so 1ohm would hurt and possibly destroy the amp. So you would be losing a decent amount of power and the surface space gained from another sub wouldn't necessarily make up for the loss in power and definately not worth the loss of space IMO. If you're not wanting to buy a new amp just keep what you have. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
AUDIOADDICT02 Posted August 27, 2010 Report Posted August 27, 2010 I believe you are talking about the rf he2's....I would tune the box to 34hz... One thing I noticed about some enclosures I built in the past is when you give a sub more port area than recommended, it tends to hit well on higher bass notes even when tuned low... CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978 DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983 PREFAB REMODELING: http://www.stevemead...box-remodeling/ G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/ CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/ KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/ RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/ 2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/ 2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
nomanaserilanco Posted August 27, 2010 Author Report Posted August 27, 2010 ok so then if i did want to run two i should get a new amp. do you guys have any suggestions as to what is a nice, affordable amp that puts out about the watts i need either at 4ohms or one that is 1ohm stable? and also do you have any advice on building and tuning a box with 2 subwoofers. and also i did notice what you ment as to it doing well on high notes cause i have a pretty large rectangular port and it does have those fluctuations in the volume but the problem is where it gets louder again in the higher frequencies is mostly when i am listening to other types of music and its a pretty loud increase and sounds un natural like if i am listening to alternative the bass guitar on some notes is blasting to where i cant barely hear the vocals
