BTL FTW Posted August 26, 2010 Report Posted August 26, 2010 I've decided to create an insane home system for music only since I already have a 7.2 system in my HT This will be in the living room and will be build over the next 3 weeks Anything above 100hz will be handled by 2 towers running stereo with with 4 sets of RE audio XXX 6.5 component sets in each on the main wall getting 1200 watts per tower from a Crown XLS Drivecore 2500 Frequencies between 100hz and 45 HZ will be handled by 2 FI Audio Q 12's each getting 1200 watts from another Crown XLS Drivecore 2500 These will be run in 1.5 cf sealed enclosures in the base of the towers Frequencies below 45 hz will be from a Loaded FI Audio BTL 18 powered by a 3rdCrown XLS Drivecore 2500 at 4 ohms for 2400 rms in a 8.5cf enclosure ported to 18hz with no subsonic filter that will serve as a coffee table The electrician is here tomorrow to run the needed power to the living room, I'm still working on source unit and the rest of things. Should have product pics up by thursday. picked up 10 sheets of 1in MDF today. Towers will be double walled and the 12s and 18 will be triple walled. By goal is full usable extension to 15hz so I can cover anything decaf has to offer and MURDER the lowest note on Jezzy Put On Feedback is welcomed!!! Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
hzsogood Posted August 26, 2010 Report Posted August 26, 2010 I've decided to create an insane home system for music only since I already have a 7.2 system in my HT This will be in the living room and will be build over the next 3 weeks Anything above 100hz will be handled by 2 towers running stereo with with 4 sets of RE audio XXX 6.5 component sets in each on the main wall getting 1200 watts per tower from a Crown XLS Drivecore 2500 Frequencies between 100hz and 45 HZ will be handled by 2 FI Audio Q 12's each getting 1200 watts from another Crown XLS Drivecore 2500 These will be run in 1.5 cf sealed enclosures in the base of the towers Frequencies below 45 hz will be from a Loaded FI Audio BTL 18 powered by a 3rdCrown XLS Drivecore 2500 at 4 ohms for 2400 rms in a 8.5cf enclosure ported to 18hz with no subsonic filter that will serve as a coffee table The electrician is here tomorrow to run the needed power to the living room, I'm still working on source unit and the rest of things. Should have product pics up by thursday. picked up 10 sheets of 1in MDF today. Towers will be double walled and the 12s and 18 will be triple walled. By goal is full usable extension to 15hz so I can cover anything decaf has to offer and MURDER the lowest note on Jezzy Put On Feedback is welcomed!!! Ummmm WEll good luck with that.. Not the drivers Id be using , but whatever.. I have a 16 CF front loaded folded horn Ive been running for a while now, and even I cant "murder" put on.. I hope your room has descent acoustics too.. My suggestion.. Folded horn over direct radiator ANYDAY of the week.. Thats what they are made for.. your putting a SPL driver in home, regardless .. If you wanted a CAR sub in your HOME , try a soundsplinter, W7, or a XXX
hzsogood Posted August 26, 2010 Report Posted August 26, 2010 These are my numbers from 6 feet behind the LP, This is what I had before and after tuning and REW. All done with RS digital meter, REW and Behringer UCA-202 20 hz - .. 98 db - 106db 24 hz - .. 102 db - 111db 27 hz - .. 106 db - 114db 30 hz - .. 108 db - 118db 35 hz - .. 114 db -121db 40 hz - .. 114 db -120db 43 hz - .. 118 db -125db 45 hz - .. 120 db -129db 50 hz - .. 119 db -127db 55 hz - .. 117 db -126db 60 hz - .. 114 db -126db 65 hz - .. 115 db -127db 70 hz - .. 118 db -130db 75 hz - .. 118 db -129db 79 hz - .. 114 db -127db
memphisbasshead Posted August 26, 2010 Report Posted August 26, 2010 sounds all good man the only thing i would change is the fi btl 18. it's kind of a spl based sub. i would get something like 3 of http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-420 in about 15 cubes net tuned to 20 hz or if you have the space or money i would get 2 fi q 18's. but i personally would go with the dayton titanics if you can afford 4 that would beat the 2 fi q 18's. if you get the 2 fi q 18's i would do 16 cubes net tuned to 20 hz but if you can afford to get 4 of the daytons that would be amazing and i would make and enclosure thats about 20 cubes net tuned to 20 hz for the 4 dayton 15's My Car Audio Setup: Sub: 1 RE Audio HC 15 Dual 2 ohm(soon to get a psi recone) Daily Sub Box: 1.62 cubes net with 2 dayton audio 8 inch passive radiators tuned to 34.35 hz, 141.9 @ 48 hz sealed on the dash with termlab Competition Sub Box: 3.10 cubic ft. net tuned to 50.58 hz with 2 6 inch aeroports, 147.9 @ 62 hz sealed on the dash with termlab Amp: Powerbass ASA 1000.1 Dx(eventually gonna get a planet audio bb2400.1) Big 3: Phoenix Gold 1/0 Gauge Amp Wire: Knukoncepts 1/0 gauge Alternator: Stock 90 amp Battery Under the hood: Autocraft Gold Top Battery Battery In Back: None for now but I am looking for one so pm me if you have one for sale HU: Pioneer DEH-2900MP Front/Rear Amp: Hifonics Txi-4408 4 channel amp Front Speakers: Orion Cobalt 6.5 coaxial Rear Deck Speakers: Orion Cobalt 6x9 coaxial Home Audio Setup: Speakers:2 Cerwin Vega D-3's (10" Woofer,5 1/4" mid-range,1" Bullet Dome Tweeter) 2 Cerwin Vega D-5's (12" Directed Audio Xtreme 124SX Subwoofer,5 1/4 mid-range,1" Bullet Dome Tweeter)Kenwood center channel and rears. Amp: 2 Kenwood KM-105's from 1985 Receiver: JVC RX-6008V 5.1 Channel Receiver Pre-Amp: Kenwood KC-993 Sub: still looking for one thinking about getting a 18 or 15 for my sub to hit the lows if anyone has one pm me I do free box designs if anyone is interested
BTL FTW Posted August 26, 2010 Author Report Posted August 26, 2010 looking at the daytons now money isnt too much of an issue so i'll buy whats best I'm also considering doing 25 cubes at 18hz with 3 FI Q18s just to have continuity with all the same sub. I've got a 26x18 foot listening space so i've got the room to go humungus on the enclosure. maybe put it behind the main sofa Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
n8ball2013 Posted August 26, 2010 Report Posted August 26, 2010 if money is no object buy shit that is designed for home theater and home audio. Car audio gear while dear to all of us is not the best option. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
memphisbasshead Posted August 26, 2010 Report Posted August 26, 2010 looking at the daytons now money isnt too much of an issue so i'll buy whats best I'm also considering doing 25 cubes at 18hz with 3 FI Q18s just to have continuity with all the same sub. I've got a 26x18 foot listening space so i've got the room to go humungus on the enclosure. maybe put it behind the main sofa well if money ain't an issue i'd get 2 of these http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-666 do 2 of them in about 18 cubes tuned to 20 hz. btw this sub is considered the best sub ever made but if you can't afford those i would definitely get 4 of the dayton's. i think the daytons would get lower than the fi q's but of you can get 2 of those lms 5400's you would have one of the sickest home theaters here's a few vids of those 2 18's in a car My Car Audio Setup: Sub: 1 RE Audio HC 15 Dual 2 ohm(soon to get a psi recone) Daily Sub Box: 1.62 cubes net with 2 dayton audio 8 inch passive radiators tuned to 34.35 hz, 141.9 @ 48 hz sealed on the dash with termlab Competition Sub Box: 3.10 cubic ft. net tuned to 50.58 hz with 2 6 inch aeroports, 147.9 @ 62 hz sealed on the dash with termlab Amp: Powerbass ASA 1000.1 Dx(eventually gonna get a planet audio bb2400.1) Big 3: Phoenix Gold 1/0 Gauge Amp Wire: Knukoncepts 1/0 gauge Alternator: Stock 90 amp Battery Under the hood: Autocraft Gold Top Battery Battery In Back: None for now but I am looking for one so pm me if you have one for sale HU: Pioneer DEH-2900MP Front/Rear Amp: Hifonics Txi-4408 4 channel amp Front Speakers: Orion Cobalt 6.5 coaxial Rear Deck Speakers: Orion Cobalt 6x9 coaxial Home Audio Setup: Speakers:2 Cerwin Vega D-3's (10" Woofer,5 1/4" mid-range,1" Bullet Dome Tweeter) 2 Cerwin Vega D-5's (12" Directed Audio Xtreme 124SX Subwoofer,5 1/4 mid-range,1" Bullet Dome Tweeter)Kenwood center channel and rears. Amp: 2 Kenwood KM-105's from 1985 Receiver: JVC RX-6008V 5.1 Channel Receiver Pre-Amp: Kenwood KC-993 Sub: still looking for one thinking about getting a 18 or 15 for my sub to hit the lows if anyone has one pm me I do free box designs if anyone is interested
BTL FTW Posted August 26, 2010 Author Report Posted August 26, 2010 if money is no object buy shit that is designed for home theater and home audio. Car audio gear while dear to all of us is not the best option. pro audio amps and car speakers will get me a lot closer to my goal than any home audio gear. My goal being AUDIO CARNAGE!!! there's no home audio gear that can handle the kind of abuse I give my gear. FI transducers have always been bulletproof for me. Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
memphisbasshead Posted August 26, 2010 Report Posted August 26, 2010 if money is no object buy shit that is designed for home theater and home audio. Car audio gear while dear to all of us is not the best option. x2 thats why i recommended the daytons and the tc sound subs My Car Audio Setup: Sub: 1 RE Audio HC 15 Dual 2 ohm(soon to get a psi recone) Daily Sub Box: 1.62 cubes net with 2 dayton audio 8 inch passive radiators tuned to 34.35 hz, 141.9 @ 48 hz sealed on the dash with termlab Competition Sub Box: 3.10 cubic ft. net tuned to 50.58 hz with 2 6 inch aeroports, 147.9 @ 62 hz sealed on the dash with termlab Amp: Powerbass ASA 1000.1 Dx(eventually gonna get a planet audio bb2400.1) Big 3: Phoenix Gold 1/0 Gauge Amp Wire: Knukoncepts 1/0 gauge Alternator: Stock 90 amp Battery Under the hood: Autocraft Gold Top Battery Battery In Back: None for now but I am looking for one so pm me if you have one for sale HU: Pioneer DEH-2900MP Front/Rear Amp: Hifonics Txi-4408 4 channel amp Front Speakers: Orion Cobalt 6.5 coaxial Rear Deck Speakers: Orion Cobalt 6x9 coaxial Home Audio Setup: Speakers:2 Cerwin Vega D-3's (10" Woofer,5 1/4" mid-range,1" Bullet Dome Tweeter) 2 Cerwin Vega D-5's (12" Directed Audio Xtreme 124SX Subwoofer,5 1/4 mid-range,1" Bullet Dome Tweeter)Kenwood center channel and rears. Amp: 2 Kenwood KM-105's from 1985 Receiver: JVC RX-6008V 5.1 Channel Receiver Pre-Amp: Kenwood KC-993 Sub: still looking for one thinking about getting a 18 or 15 for my sub to hit the lows if anyone has one pm me I do free box designs if anyone is interested
memphisbasshead Posted August 26, 2010 Report Posted August 26, 2010 pro audio amps and car speakers will get me a lot closer to my goal than any home audio gear. My goal being AUDIO CARNAGE!!! there's no home audio gear that can handle the kind of abuse I give my gear. FI transducers have always been bulletproof for me. umm actually no the pro audio equipment would work great but car audio equipment is made for car audio hence the name car audio most of the time home audio stuff will work better for home audio applications which is why the call it "home audio" audio equipment is geared differently for different applications thats why car audio stuff works best in cars and why home audio stuff works best in homes and why pro audio stuff works best for pro audio. and what i have told you is a fact not an opinion lol My Car Audio Setup: Sub: 1 RE Audio HC 15 Dual 2 ohm(soon to get a psi recone) Daily Sub Box: 1.62 cubes net with 2 dayton audio 8 inch passive radiators tuned to 34.35 hz, 141.9 @ 48 hz sealed on the dash with termlab Competition Sub Box: 3.10 cubic ft. net tuned to 50.58 hz with 2 6 inch aeroports, 147.9 @ 62 hz sealed on the dash with termlab Amp: Powerbass ASA 1000.1 Dx(eventually gonna get a planet audio bb2400.1) Big 3: Phoenix Gold 1/0 Gauge Amp Wire: Knukoncepts 1/0 gauge Alternator: Stock 90 amp Battery Under the hood: Autocraft Gold Top Battery Battery In Back: None for now but I am looking for one so pm me if you have one for sale HU: Pioneer DEH-2900MP Front/Rear Amp: Hifonics Txi-4408 4 channel amp Front Speakers: Orion Cobalt 6.5 coaxial Rear Deck Speakers: Orion Cobalt 6x9 coaxial Home Audio Setup: Speakers:2 Cerwin Vega D-3's (10" Woofer,5 1/4" mid-range,1" Bullet Dome Tweeter) 2 Cerwin Vega D-5's (12" Directed Audio Xtreme 124SX Subwoofer,5 1/4 mid-range,1" Bullet Dome Tweeter)Kenwood center channel and rears. Amp: 2 Kenwood KM-105's from 1985 Receiver: JVC RX-6008V 5.1 Channel Receiver Pre-Amp: Kenwood KC-993 Sub: still looking for one thinking about getting a 18 or 15 for my sub to hit the lows if anyone has one pm me I do free box designs if anyone is interested
