Posted (edited)
Some of the time when the internal ground circuitry goes out on an amp board, you get what you are hearing along with alternator whine...
What are all the things along the inside of the case with the heat sink stuff on them.
one of those has a mark where it got shorted out or something.
Edited by kx519
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
Kinda like this?
If so mosfet.
Yea those, Well one of them have a burn mark on the center pin.
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
Sounds like your problem...lol burnt up mosfets
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
Can i pull one from any amp? seems like an easy fix
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
Posted (edited)
We're sure this is the amp correct? What if you swapped amps out and see if it still happened?
Sorry, I'm just trouble shooting..
EDIT: I should of read the second page... :X
Good luck with it
Edited by TLEJ
When replacing mosfets, you should replace all of them with new ones that are of the same batch. Otherwise you are asking for more failures down the road.
97 Maxima SE
Bunch of shit going in, check out the build
Posted (edited)
To me it sounds like it's going in and out of protect. Some amps make a weird ass squeal or scratching noise when they go into protect. I've heard it with MMATS and DAT. In both instances the amps were hosed (one had fried fets and no idea what was wrong with the other one).
EDIT: balls more posts by the time I hit send <_<
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
yeah those with the heatsinks are transistors, they amplify signals so that a pretty big part in an amplifier lol so if they blow then you will need to replace them, if your board is burnt in more places then id say ur amp is screwed and you should just get a new one
2x Sundown Audio SA-15's nuff said for my little old car
1999 Plymouth Breeze Build Log
I'll try new mosfets, sounds simple enough and if that doesn't work then i'll fork out the money for a new amp.
Any good places to buy new mosfets?
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
  • Who's Online   0 Members, 0 Anonymous, 577 Guests (See full list)
