kirill007 Posted August 26, 2010 Report Share Posted August 26, 2010 Dude get the fuck out you are not helping at all. Please quit post dumping... Really? Couldn't tell. I appreciate your input. I see what u guys did there. Check the ground? and maybe dwz is right, open it up or go back to where u bought it and ask them to look. Quote Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
Rebel4055 Posted August 26, 2010 Report Share Posted August 26, 2010 its at 1 ohm. and it has been for a year now. the only thing that has happened is the power leads broke off and i had to solder them back on. Did the solder possibly melt and run onto something on the amp? Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
techforce Posted August 26, 2010 Report Share Posted August 26, 2010 (edited) Could also be the RCA inputs of the amp, if they grounded out while the amp is on, that could cause that as well... but, no matter what, seems like there is something wrong with your amp... Unplug the RCA's and use a ipod to rca cable and play thorugh that, to eliminate the head unit or rca's Edited August 26, 2010 by techforce Quote Link to comment Share on other sites More sharing options...
kx519 Posted August 26, 2010 Author Report Share Posted August 26, 2010 I see what u guys did there. Check the ground? and maybe dwz is right, open it up or go back to where u bought it and ask them to look. the ground is fine. The internals are as clean as a whistle. other than one spot where a strand of wire off my 1/0 crossed a capacitor. but that was a long time ago. Ordered it onling. a year ago. Did the solder possibly melt and run onto something on the amp? Nah. i double and triple checked. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd--> Link to comment Share on other sites More sharing options...
Skullz Posted August 26, 2010 Report Share Posted August 26, 2010 The solder from the board itself may have seperated from the connection causing it to contact for short period and losing contact, might want to really look closely at that. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
kx519 Posted August 26, 2010 Author Report Share Posted August 26, 2010 Could also be the RCA inputs of the amp, if they grounded out while the amp is on, that could cause that as well... but, no matter what, seems like there is something wrong with your amp... Unplug the RCA's and use a ipod to rca cable and play thorugh that, to eliminate the head unit or rca's I tried that also. It does the same thing. Actually it's worse. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd--> Link to comment Share on other sites More sharing options...
kx519 Posted August 26, 2010 Author Report Share Posted August 26, 2010 The solder from the board itself may have seperated from the connection causing it to contact for short period and losing contact, might want to really look closely at that. Well to prevent the leads from ever breaking off again i drilled and tapped them out and put a screw in them. I checked and made sure they aren't shorting out or anything. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd--> Link to comment Share on other sites More sharing options...
techforce Posted August 26, 2010 Report Share Posted August 26, 2010 I tried that also. It does the same thing. Actually it's worse. The amp then... may have to send it in for repairs or get a new one... if all the connections are solid, then it is the amp... when the car runs, does it pick up any noise from the electrical? Quote Link to comment Share on other sites More sharing options...
kx519 Posted August 26, 2010 Author Report Share Posted August 26, 2010 The amp then... may have to send it in for repairs or get a new one... if all the connections are solid, then it is the amp... when the car runs, does it pick up any noise from the electrical? Like alt whine? None of that. I spent some time making sure i never got any of that. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd--> Link to comment Share on other sites More sharing options...
techforce Posted August 26, 2010 Report Share Posted August 26, 2010 Like alt whine? None of that. I spent some time making sure i never got any of that. Some of the time when the internal ground circuitry goes out on an amp board, you get what you are hearing along with alternator whine... Quote Link to comment Share on other sites More sharing options...
