amp as line drive?
jake1993
could i use a small amp i have sitting around as a line drive?
so like this (headunit) =(rca's)= (small amp) =(Speaker wire to high level) =(current amp) and get a better signal to the current amp than
(headunit)=(rca's)= (Current amp)? ^ everything turned down
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
i dont think it would work you might cause somthing to fry. get a pre amp or crossover with higher out put than your head unit.
Its been done just be careful there is a huge potential of smoking something!
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
even if it works its gonna more than likely be dirty power
Yeah it would work depending on what voltage the speaker inputs on the second amp could handle. But what's the point? You're just adding another source of noise and distortion to the signal path. I would bet $10 that the RCA output on your deck is way cleaner than the speaker outputs on a small amplifier.
10.x volts fo' life!
i was just wanting to know if it would work and be any better than just going strait to the amp cause im going to be cutting it close trying to get a new amp so i wont have any extra money to get a line driver and dont like having the low pre amps i have
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
If you want a really cheap line driver just pick up a PAC Turbo-1
  • Who's Online   0 Members, 0 Anonymous, 955 Guests (See full list)
