ianbasstech2010 Posted September 1, 2010 Report Posted September 1, 2010 How would I hook up the rca and remote wire to all 4 amps? Would I just run the main wires to one amp and run a wire from the amp to the next and so on?
huh?do-what? Posted September 1, 2010 Report Posted September 1, 2010 you should be able to hook rca to first amp. Then from the rca output, jump it to the next one and the next one and so on. As for the remote wire, you might do the same, but I would use a relay from the radio remote wire, then split it to all of the amps. God damn its hot today. My balls are stuck to my leg.
ianbasstech2010 Posted September 1, 2010 Author Report Posted September 1, 2010 What would I do for the amps with just the one set of rca inputs?
n8ball2013 Posted September 1, 2010 Report Posted September 1, 2010 not on the orions. They dont pass the voltage through well. You need to y split them off. or make a hobby box. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ianbasstech2010 Posted September 2, 2010 Author Report Posted September 2, 2010 Ya but the y splitter runs to two amps from the deck, right?
n8ball2013 Posted September 2, 2010 Report Posted September 2, 2010 think about how you'll split voltage to four amps. use a y split with 1 female to 2 male on each rca connector. Then do it again. You will have the same output voltage across all connectors. Yes it will be ugly. but it shouldn't be seen. yes you may have a little voltage loss but if your gains are set accordingly it makes no difference. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ianbasstech2010 Posted September 2, 2010 Author Report Posted September 2, 2010 Oh Dang. Ur right, I wasnt thinking haha but thanks bro.
n8ball2013 Posted September 2, 2010 Report Posted September 2, 2010 no problem. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
