Alright I'm fairly sure I will be Doing 2 270 amp alts from mechman with the switch to control how much volts the battery sees. If I just use xs d3100 I will hopefully be around 14.7 - 15 volts what could I do to get more out of it or maybe get a stable flow at 15 - 17 volts. Or maybe its all good just leaving it that way.
It will be for 2 4500 watt amps subs will be set to .5 each. Each amp will have 2 batts d3100
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
^^ hahah,, let him find otu the hard way with out a 16v setup you should be fine as far as dual alts maybe 3 batteries per amp. if you want solid voltage
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Ya no shit I know that lol I'm saying what should be better would a 16v from kenetic be solid or better then a 12 from xs ? And last?!
Alright ill just talk to Nathan then! Thanks!
Whats the difference Robert between d3100 and that d1400
id say after 15 volts on your car you run the risk of frying your cars stock electrical components, you would have to do a step-down wiring system on everything except your audio
http://www.stevemeadedesigns.com/board/topic/75284-18-volt-daily-driving-diagram/page__p__1186489__hl__18%20volt__fromsearch__1entry1186489
^^^ check this diagram out for wiring in step-downs for a high volt system.
2x Sundown Audio SA-15's nuff said for my little old car
1999 Plymouth Breeze Build Log
If you run 14v batteries and a 14v setup (should actualy charge and run at about 15-16volts) you "should" be ok with the stock electrical and your truck stock electronics should be ok. If you want to run 16v batts. (17-18+ volts charged) it's honestly not worth the money to do so. I think you still want a VCM so give nathan a message or call and talk to him about what he recommends. The d1400 is a 14v battery. The d1600 is a 16 volt battery. They are both rated for about 3,000 watts rms a battery.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Ok kool kool just the vcm and d1400 should be keeping my shot good with out running a step down... Just making sure I'm with ya here.
