if you cant find a pink wire in the ignition column you need to get someone else to do this.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
red all i see is a red
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
the pink on gm looks VERY close to red. in dim light u cant tell the difference. metter all the "red" wires till u fint one that turns on and off with the key. or the brown is an acc too
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Alright so I am going to do what with the wire just slice it and attatch what wire from my deck
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
http://members.shaw.ca/johnz24/howto/7/7.html
this sounds right
In order to turn your new aftermarket deck on and off with the ignition, you have to tap onto a wire that carries +12V when the car is ON and in ACC. There's a brown wire in the ignition harness that you can tap. It's a heavy wire (12 gauge) compared to most other wires around it. There arealso two red wires, and a yellow, pink and orange there too - if GM changes the wire colours, use a voltmeter to check which wire carries +12V during the ACC and ON key positions. If you are tapping this wire - FUSE IT!
An 'easy' alternative is to use a fuse tap on the windshield wiper fuse. This is a plug which replaces the factory fuse and adds a new fuse (along with the original one) and has a wire for the new circuit. Using the windshield wiper fuse is an old installer trick, and it sure does work! Plus by using the fuse tap, you don't have to cut any of the factory wiring. You also don't need to worry about overloading any existing circuits, because ineffect you are creating a new one.
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
