OK so I bought a new headunit because my other one the faceplate wont stay on and it just like wont work out for me. I got a Eclipse CD1200G cause I wanted the stock look. I have a 2000 cavalier 4 door and have installed many decks but have never seen anything like this. I wired it all up and bam it came on but then I realized I never turned the car on and the keys were next to me on the seat..... so I drew up how I wired it and tell me where I went wrong. Thanks guys!!!!
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
where is the ground from the head unit? what does the top right thingy say? try writing on paper and taking a pic and posting it here because this just looks like you had a siezure while writing this. and id say double check your ignition wire that its not connected to the battery instead
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
For my car I have to have a chimes unit made by sosche so yeah thats what it is this was drawn in 3 min
Also the ground from the hu is not hooked up to anything I did hook it up to metal frame and nothing changed
Edited by marquettefan247
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
im pretty sure that car does not have a 12 volt switched source in that harness the box labeled chimes should have a red wire coming out of it. this car uses DATA for the accesory u might have to run your own acc from the ignition harness
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
check your 12volt ignition wire and 12 volt constant wire with a meter to make sure they arnt switched
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
im sorry i do not know what chimes is but hey at least you know you can draw quick if needed!
thats correct no switched power at the deck. Go to the ingition colume and tap the pink wire.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dont see any pink ones
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
This...
Live life to the full... Then TURN THAT BITCH UP!
ok the constant from the chimes to the actual harness was somthing that was preonnected and I have used this wiring harness before.... any other suggestions
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 2689 Guests (See full list)
