how to make 6.5 fit in 6x9?
chapo123
EDIT: Double post FTL, for some reason the forum is going goofy on my computer... anyone else?
yeah but i would be going smaller not bigger lol
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
and plus the mid is 6.5in wide not like the 6x9 that is only 6in wide.. would that be prob?
yeah same here forum is messing up..? and so that adapter thing would work?
it SHOULD work... My buddy used something like that in his rear deck.. Just search google for 6x9 to 6 1/2 speaker adapter plates... Ill talk to him tomorrow about where he got his.
alright thanks. any one else?
Well, the stock speakers in the explorer were more like 5x7s, but a 6.5 to a 6x9, is easy. make the cutout diameter for the 6.5, then cut the board around that hole so it will be big enough for all of the stock screws to be able to screw into the wood, mount the speaker on the bottom of the board then screw the board up to the bottom of the 6x9 hole, the 6x9 screws shouldn't touch the 6.5 at all. I'd do it cuz you can make the adapters for like $3.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Get you some masonite trace out the shape of the 6x9's the cut out the shape of the 6.5 in the center. And for the flush mounted tweeters get a drill and a cut out hole for a drill that is the size of the cutout for the tweeter and line up both panels and make sure they are even and drill away. Good luck
"NOT AT THE TABLE CARLOS"
  • Who's Online   0 Members, 0 Anonymous, 1234 Guests (See full list)
