drewb53 Posted September 8, 2010 Report Posted September 8, 2010 I was messing around in my blazer today, and i am waiting on my amp to come in before I put everything in. Anyways i was looking around and the place i wanted to mount my amp would require either the rcas or the power to be run more than needed. I was wondering if I could mount the amp on the top of my box? I know that people say it isnt good to do, but i was thinking that i would put rubber washers under each of the mounting feet. Let me know what you think. 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car.
jeyrapboy Posted September 8, 2010 Report Posted September 8, 2010 You should be fine man... Mine is mounted to my box with shims and rubber feet between the amp and the box... Protects the amp and lets a little air flow behind the amp.
lance_98main Posted September 8, 2010 Report Posted September 8, 2010 Way i look at it is if your box is build solid and there is no flex in it then there should be no vibration to the amp if it's mounted on it. 2000 2dr blazer 15" diamond audio d3 4 cubic ft. tuned @ 32hz (slot port, sub back, port back) debating on a wall or no wall. Shay-kee
drewb53 Posted September 8, 2010 Author Report Posted September 8, 2010 well the box is solid, but i think i may still do rubber washers to get it off of the box a little. Also just for the peace of mind. 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car.
