bumonskateboard6 Posted September 9, 2010 Report Posted September 9, 2010 So amp is a rockford fosgate t1000 2009 model, the amp was installed in a friend/clients car running a dc lvl4 15 and all set with a multimeter at 59/61 on the HU. The sound stopped working after about three months so I figured it was the sub but the sub coils read fine, then I put the dmm on the amp and although it was on and not in protect there was not any output voltage anymore. I'm just trying to figure out what went wrong with this, the amp is being repaired right now. I think he somehow managed to clip the hell out of it because when I took the amp out it was too hot to even touch the metal on the back. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
bumonskateboard6 Posted September 11, 2010 Author Report Posted September 11, 2010 no ideas? Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
tristan560 Posted September 11, 2010 Report Posted September 11, 2010 I'm willing to bet the voltage dropped too low. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
bumonskateboard6 Posted September 11, 2010 Author Report Posted September 11, 2010 I'm willing to bet the voltage dropped too low. Thats something I was afraid of because he had an old battery that died on him and the problem happened shortly after he got it replaced. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
tristan560 Posted September 11, 2010 Report Posted September 11, 2010 As long at it was being ran at a safe load id say it was too low of voltage. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
Boon Posted September 12, 2010 Report Posted September 12, 2010 Low voltage does not kill amps. I have never, ever seen an amp that blew because the voltage got too low. They go into protect first. 10.x volts fo' life!
bumonskateboard6 Posted September 12, 2010 Author Report Posted September 12, 2010 Low voltage does not kill amps. I have never, ever seen an amp that blew because the voltage got too low. They go into protect first. Amp never went into protect (as far as I know, not in my car) however the amp was on with no protect light on and when I tested a 50hz sine wave through the multimiter it was reading 0 volts no matter how high I'd adjust the volume on the deck or gain on the amp. It seems almost like the output terminals got completely desoldered from the board Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
skaraudio Posted September 13, 2010 Report Posted September 13, 2010 Amp never went into protect (as far as I know, not in my car) however the amp was on with no protect light on and when I tested a 50hz sine wave through the multimiter it was reading 0 volts no matter how high I'd adjust the volume on the deck or gain on the amp. It seems almost like the output terminals got completely desoldered from the board Wow that seems really weird. It should have at least went into protect if a voltage problem. Skar Audio www.SkarAudio.comPhone : (888) 501-7527
