are you refering to the gain?
and what are the voicecoil configurations? im not familiar with the TNT from american bass...
what do you mean you have it set at half? gain at half or you scoped your settings at half?
if im not mistaken TNT isnt that great of a brand, so i would assume hes referrin to his gain. so you know OP. theres no way to set your amp 'half way' or any way to limit power just by turning the knobs. kicker warhorse excluded lol
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
right now i have the amp setting for output at half
i am running the voice coils at 2 ohms all of the amp setting are at half right now because i dont have enough power to go max on all the settings
Wonderful. I'd say you're one mistake short of frying both amps and destroying your subs.
I suggest you go to Radio Shack, buy a Digital Multimeter, and set your gains on your amps the right way. Here's a few links to help you on your way.
Grab your test tone for your CD from here: http://realmofexcursion.com/index.php?pageid=audio_downloads
Or use Decaf's 45hz tone (the one I use) found here: http://www.stevemeadedesigns.com/board/topic/44109-decafs-screweddemo-collection/
This will get your gains set PROPERLY. Also, definitely look into upgrading your battery and doing the Big 3 before adding a capacitor.
Edited by Maxim
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
2. Specs:
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V—16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 12.75″(L)x9.27″(W)x2.35″(H)
thay is my amp specs
his gains would only be set properly if they amp does rated and not over or under, and its overrated
i assumed he was running two AQ1200s....
im thinking the wiring is incorrect and so hes trying to compensate for the noob mistake by upping his gain.
2. Specs:
870X1 @ 2 ohm,
1200X1 @1 ohm
i was asking for the voicecoil configurations on the subs. as in how are they wired into the amps? is 2ohms the final ohm load running two per amp?
You think his AQ 1200's are overrated?
wtf is lolcats?
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
