Subwoofer is a DVC 4 ohm, wire the coils in parallel for a 2 ohm load.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
An example of a compatible amplifier.
http://www.sonicelectronix.com/item_9852_Rockford+Fosgate+Punch+P300-1.html
Name/brand of woofer?
EDIT: and to answer your question, yes it is safe, as long as the amplifier is 2 ohm stable.
Edited by Cardboardcat15
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
The Alpine Skullz put up will do you ok and save you some coin which you can buy the wiring kit with and a box if you dont have one :)
I run alpine on my pioneer sub and it works like a charm
NRG Do you have the same sub? Thx!
I dont sorry i have the Pioneer TS-W 3004 SPL powered by an alpine pdx1.1000 with a secondry battery on a 100amp alternator with 4awg and recent 250amp anl fuse.
kept popping the 80amp agu's lol
friend of mine had 2 of your subs though powered by alpine mrd 605 i think it was and that was good too.
as for box making well i learned that lesson in a hurry.
i built a box to the sub specs and it was laaaaaaaaaaame. i then experimented and found that a big ported box had more boom.
lots of info on the net and especially on here about boxes, Whats to loose really as you can only learn by mistakes and i gotta admit its fun too. After some experimenting i ended up with a double the size box with a slotted port and man does it bang for what it is 8)
This will be my first box that i have made for myself and I'm expecting some mistakes to occur! lol thanks again for all the great input. i posted this question in subwoofers / enclosures but i was wondering if you guys knew if there is a difference is sound if i were to put the sub facing up in a "L ported" box compared to parallel to the port? if not. Thanks anyways!
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
