whineeeee
fox_racin4
alrighty so i picked up the atomic 7k andddd got it all hooked up and playing
i was in backseat and heard a whine comming from subs so i unhooked the sub RCAs thinking it was a ground loop and it was still there even without the RCA in the amp
should i be worried?
its not like.. loud i cant hear it in front seat but if im in the back seat i can hear it with volume all the way down
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
yes no RCA plugged in just power
i tried re grounding as well
i was told it could possible be some sort of filter?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Could be a dodgy output filter... or dodgy input op-amp... or drive circuit on the way out.
Are you sure it's the subs, not the amp itself humming?
10.x volts fo' life!
positive its from the subs its not loud but if i stick my head in the back seat i can hear it
the thing that confused me is it does it even without any RCAs plugged into it
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i had a SAZ1500D do this on me, exactly what you're describing soon after, she was kaput,,, look out :peepwall:
edit: as soon as the remote clicked the amp on, it was like very quiet untill it was a constant noise a few sec after almost like a dog whistle
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
I had an amp start doing that, couple min after I noticed it, amp went and sent straight dc power to my woofers.
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
That dog whistle sound is either a loose output transformer or the sound of high pressure smoke pissing out the side of your MOSFETs.
Either way, not ideal.
I dunno if this is what OPs problem is. Whistling amps don't last long.
:werd_msword:
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 1064 Guests (See full list)
