Guest Nismofreak
HAHA nice engine.....now get a turbo on there after you pay back your parents.....can't wait for mine...
well it runs but the idle is TERRIBLE. Above 2000 rpm its INSANE Runs great. But its running really rich at idle. Like just a little bit of black smoke and choppy idle. So i dont know wat to do. Im geussing its a sensor. We played wit the set screws on my intake manifold but it only helped a bit. I checked all my wiriing. So i took the negative off the battery hoping it might reset somthing. Anyone have any sugestions ??? or thoughts ???
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
Well check all your connections and make sure they are all in the right spot .
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
my buddy said youre running it too rich. he said get an air/fuel controller and that might help. dont ask me!!
Ya its deffintly running to rich. I will look into this air fuel controller. thanks for the response.
System Specs:
MTX Bass Knob
80 amp stinger fuse
no problem. he said its way too rich is its blowing black smoke at idle.
k Tommorow and monday were going to figure this out. Because it runs amazing past around 1700-2000 rpm. Even if you give it just a little rev maybe to 1000 rpm it is perfect. Its just IDLE. I asked a nieghbor and he said flashing the ECU or trying another one may fix it.
System Specs:
MTX Bass Knob
80 amp stinger fuse
Guest Nismofreak
Nice to hear that the engine is installed...now get some videos of the new engine running...I wanna see the beast in action...
this vid is EXACTLY how my car is running. Idles terrible but is normal the second u rev it. And i have the same black smoke he has but not as bad.
System Specs:
MTX Bass Knob
80 amp stinger fuse
Try this boss man tell me what happens if it works or what...IAC Valve...Idle Air Control Valve...Here is a write up about it...Also make sure you check all your vacumn lines make sure they are all on and not cracked leaking air...IAC Valve could be your culprit..Let me know what happens..
http://www.honda-tech.com/zerothread?id=1575913
