Rogers Posted September 21, 2010 Report Posted September 21, 2010 so im going to be needing a way to secure my new kinetiks... and i figured... well hell.. kinetik makes sleeves for em.... so my question is... what positions do these cases alow the battery to be mounted in? i couldnt find any detailed info on them... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
MECHMAN Posted September 21, 2010 Report Posted September 21, 2010 Kinteik batteries can be mounted in any position except upside down. In my opinion though, those sleeves are a little flimsy to use as mounting brackets... 1-888-MECHMAN www.Mechman.com [email protected]
baaudio Posted September 21, 2010 Report Posted September 21, 2010 the sleeves just have holes in the bottom to screw them down. id recommend just making your own mounting bracket. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Rogers Posted September 21, 2010 Author Report Posted September 21, 2010 what would you suggest? one is going under my hood (HC1400) and one is going in my spare tire well(HC2000) both will be mounted on their side... im just trying to figure out the best way to secure them http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
baaudio Posted September 21, 2010 Report Posted September 21, 2010 you could buy some pieces of flat bar and just cut and bend them to length. or take some scraps of mdf and make mounts. heres how i did my bracket up front. bolts go through the bottom of the factory battery tray and heres one the ones on my rear batt. i have one on each side. made this out of 1/2" mdf scraps Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Rogers Posted September 21, 2010 Author Report Posted September 21, 2010 damn! thats pretty sexy for some home made fab work... i like it http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
baaudio Posted September 21, 2010 Report Posted September 21, 2010 thanks haha. i put the sticker on cuz it looked hella plain. but i just measured then put it in the vice and bent some 90s edit: i also put some foam tape under it so i wouldnt scratch up the battery Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
