Where to run 1/0 Power Cable on a 04 Tahoe?
Just finished putting the BIG3 on the hoe today. Pictures to come. Tomorrow going to run the 1/0 power to the amp rack that will be under the 2nd row seats..  Thanks for the help guys! Shannon
2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
Here you guys go. I know "Clean the Engine Compartment"! LoL
DSC00611.JPG_thumb
DSC00612.JPG_thumb
DSC00613.JPG_thumb
DSC00616.JPG_thumb
looks as if you did the big 3, way to go. change that stock battery out and get you a optima with custom terminals on the top and you'll be good to go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Thats my next step. Going to keep the stock up front and adding the Optima in the rear. Shannon
change the stock in the front along with putting one in the rear, that's the way to go, keep both batteries identical. i've heard it's not goo to mix batteries not alike together.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
well usually when wired in parallel the battery's will only hold the max energy thats in the bettery that can hold the least... but if using a isolator then it wouldnt matter
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
  • 2 years later...
hey I gotta question I have 1/0 guage running to my amps in my 99 tahoe will running 4ga for the big 3 cause any problems b/c i heard its lil hard using 1/0 for the big 3 on my truck.
I ran mine on the right side of the car underneath the trim.
the left side has the most speaker wire at least for the mine so it would interfere too much.
once I got close to the firewall I drilled a hole in the door frame and wired it in between the wheel well and up into the engine compartment.
Wouldnt be thehoe92 without teh purple
  • Who's Online   1 Member, 0 Anonymous, 1400 Guests (See full list)
