well today i shall attempt my new box w/ sum help do to a injury. anyways according to the calculator if i build the box thats 32w 24 h and 26 d and a port thats 3 h 16 w and 9 d will give me 30.83 hz. subs will be inverted and will be roughly 8.84 cubic fee. big enough for 4 12" subs. my question is the port area enough and how would i calculate the 2x4 that i will be usen for center bracing.:noob:
Team DBs (Driven By sound)
To calculate the 2x4, you could do height x width x length(in inches), go to onlineconversion.com and convert from cubic inches to cubic feet and input that number in the bracing displacement box in the calc...as for the port area, I wouldn't be able tell you if its enough since I'm on my phone right now(sorry), but there's a port area range on the calc that you should stay within...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
the port area per foot says 5.72 squared. and i'm using a 2"x4" by 24" board just cuz its free and handy
You should try to stay between 12-16 square inches of port area per foot with that type of port
k and part 2 of my question will that box be to much for 2 12's until my other 2 get here
Yes it will...
Try a bigger port and see what you net volume would be afterward...
so should i go higher or wider to achieve that
What ever works for you man. But remember increasing the port area will rise the tuning. And to bring the tuning down again will decrease the volume in the box. Meaning you might have to make your box bigger.
