uhoh_45 Posted September 27, 2010 Report Posted September 27, 2010 where do you get the tubes for your aero ports? are they normal pvc/abs you can get at home depot or do you have to special order them? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
15VmaxXL Posted September 27, 2010 Report Posted September 27, 2010 i use schdule 40 pvc. If you want a thicker pipe, get sch eighty Im an electrician apprentice, so i can get pvc from either my boss or the plumber. Check plumbing supply store. Home depot only carries 4" sold everything
dsmbasshead Posted September 27, 2010 Report Posted September 27, 2010 an aero port isnt a PVC port. They are both round but a flared port has a flared end or 2 flared ends while pvc is a perfect cylinder...i got my aero ports from parts-express.com...was 33 for 2 3" complete kits(including shipping) 1998 Mitsubishi Eclipse GS N/A 420A MTX DD 3515 Build Coming Soon! 1 Corinthians 10:31 whatthefitment.com My Cardomain
uhoh_45 Posted September 27, 2010 Author Report Posted September 27, 2010 an aero port isnt a PVC port. They are both round but a flared port has a flared end or 2 flared ends while pvc is a perfect cylinder...i got my aero ports from parts-express.com...was 33 for 2 3" complete kits(including shipping) no i know that, if you re-read what i had asked for where do you get the tubes for your aero ports? i already have 3 4" flairs/ends and 6" Tube for them and am looking to lower tuning so that is why i am asking about the tubes themselves found these online but are expensive so i'm going to check out some plumbing places instead (sorry for coming off like a dick) R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
dsmbasshead Posted September 27, 2010 Report Posted September 27, 2010 no biggy man...sorry for the misunderstading 1998 Mitsubishi Eclipse GS N/A 420A MTX DD 3515 Build Coming Soon! 1 Corinthians 10:31 whatthefitment.com My Cardomain
Boon Posted September 28, 2010 Report Posted September 28, 2010 I just use 151mm (6") plumbing PVC. It's weird though, sometimes it fits perfectly and sometimes there's a slight lip where it meets the flare. Nothing a quick bit of sanding can't solve but I guess they're not overly consistent in the wall diameter of the pipe. 10.x volts fo' life!
Robert8252 Posted September 28, 2010 Report Posted September 28, 2010 Lowes carries all sizes of PVC. 2", 3", 4", and 6" I believe. Maybe even 8". Atleast mine do so try there 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
fecupe2001 Posted September 29, 2010 Report Posted September 29, 2010 Glad to read this topic, always had this question, so in other words, i can buy my aeroports and whenever the hell i want, i can get those ports outside that box and re-use the flares with a pvc tube of the same diameter that the old aeroport tube??? very nice!!!! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
