So I need to wire to ~2ohm total load for each amp to see 1 ohm. I really appreciate you guys trying to help, this is my first experience with strapping amps and I don't want to fry something or void my warranty. VC's parallel/subs series, like so http://images.the12volt.com/12voltimages/3_1ohm_dvc_1.5ohm.gif
SMD Super Seller
My Feedback Thread
ok so ive never done parallel/series wiring configs but i gave it a shot
1.4x3=4.2/2 = 2.1/2 = 1.05 load each amp
:shrug: damn man im trying to help but im not really sure if im right lol
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
You're better at the math than me, hopefully someone will chime in and confirm/deny what you got.
SMD Super Seller
My Feedback Thread
Are they 1.4 ohm, or is that the DC resistance???
Get dual 2's, series the coils on each sub (4 ohms), parallel the three subs for 1.33 ohms. Each amp sees 0.67 ohms. No problem for those amps.
Current system:
Previous systems:
I've already got the subs, 1.4 vc. Reading 1.7-1.8 on the DMM.
So should I http://images.the12volt.com/12voltimages/3_1ohm_dvc_067ohm.gif
or
SMD Super Seller
My Feedback Thread
this one
3- 1.4 subs puts you at 2.8 when wired in series thendivide that by 3 you get.933 that is the ohm load at amp then when you strapp them they see half of that so .46 as long as you have electrical you should be fine, i have my ddm4s at .35 and they play music all day but they will protect at 30hz and below if im railing on it. cause my imped drops when the box unloads all its air at least thats my theory
Edited by dc98hoe
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1464 Guests (See full list)
