Idk what the nominal would be, but if its 1.34 like what was said above,then it would be .67 ohms per amp
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
ok i think it would be 0.93 ohm load vc in series subs in parallel i think??? so that would give you a .46 ohm load to each amp, then again someone else who's better at this might want to chime in lol.
Edited by pheint_1
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
Obviously I'm not the smartest at this shit, but how do you get a 1.34 nominal load with with THREE dual 1.4 subs? Wired to a single amp series/parallel, you get just under a 1 ohm load. Two amps strapped, with the same wiring configuration would still be around a final 1 ohm, so how much would each amp see?
SMD Super Seller
My Feedback Thread
I think you could get 2.1 ohms or .93 before rise
Edit: so 1.05 ohm or .465 per amp
Edited by hdorre
LMFAO so true
:blush:
alright so this is how i did the math idk if its correct though
dual voice coils 1.4+1.4 = 2.8/3 subs = 0.93333/ 2 amps = .46666 load each amp
:shrug:
also different equations apply when doing all parallel wiring, series/parallel and parallel/series
Edited by pheint_1
OK, i'm on the same page with you there, but what would each amp see at .93? Would it be .46 or 1.8 per amp?
at .93 ohms, each amp would see .465
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
