hi i was thinking about putting some red led around the mirror in the headboard on my water bed and i was wondering do i need to put a resistor before each led or just one resistor before the first led any help would be apreciated
Thanks
KCowboy620
!999.5 Volkswagen Jetta
1 Planet Audio BIg Bang 15
Powerbass 1500,1
Depends on the specs of the leds, the specs of the resistor, how you wire them (ie series, parallel, etc), and how many of each you would use. A comparison between how many watts the leds are (keep in mind this is related to voltage though) and the same with the resistors is a good start.
what voltage source are you using
what is the voltage drop across the LEDs
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
