2004 GMC Envoy Radio Harness??
neverminds
Well i didnt get the time to tear out the console or the rear deck in the back of the truck to look for the amp. But from what ive read and seen it is all amplified thru the radio not a external amp unless its the onstar/bose model
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
ok, i know that im bringing back an old as hell thread but why bother making a new one :P .
But i have as listed in the op, a 2004 gmc envoy. it is totally stock, no onstar, wheel controls, dvd, not even bose installed. but today when i looked at the back of the radio i noticed it had 2 areas where the wires go into the radio. so there are 2 wire harnesses that come into the stock h/u. from what may03lt stated, i could get away with a 70-2003 wiring harness from metra that would not give me the stock alarms that alert you about your tach/gauges and all that stuff going on. i dont need the chime to work since i find it to be annoying so my question is to which harness i need to wire up to. i unplugged the harness that is toward the left of the radio (when you are facing it from the rear) and the radio still worked, door chimes worked, lights dimmed the way they were supposed to and everything. so what is this wire harness i pulled used for?
what do you mean a switched lead to the h/u? i could care less about the retained power, its kinda stupid because it doesnt last long enough before i have to flick the key and turn it back off. and as i said before the chimes are annoying as hell to me.
But that part # u gave me for the cheap one looks like my adapter i have for the 24-pin female connector i used on my 1998 oldsmobile 88. is it the same??
The factory radio doesn't have a turn on lead (the one that normally goes to the red wire of an aftermarket head unit). It turns on via a bussed message. So you would have to wire in the deck to a circuit that turns on with the key in the run position and off with the key in the off position.
Chances are it's the same, that harness covers a lot of gms from the late 90s up.
Also, I don't remember what that C2 connector does but it is not needed for aftermarket radios. Mines been sitting unplugged for 3 1/2 years.
  • Who's Online   0 Members, 0 Anonymous, 569 Guests (See full list)
