ok i know you guys are probably getting a little annoyed with my ice chest radio questions but here is my question.i currently have a lawnmower battery powering a 300 watt amp and a dual media receiver and it'll play all the way up on 42 for about 30 mins. my question is if i buy a car battery would it play any longer. also can you suggest any ways for me to conserve power. i have a video of it posted on the main site and i will post a link to it
Posted (edited)
what are the specs on the current battery? im sure theres something better
Edited by baaudio
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Posted (edited)
ya, if your running the battery dead each time i would say a optima yellow top since its a deep cycle. but your going to kill any battery if you do that. looks like you have room for a G31 battery. should last a while longer. obviously that amp is whats using up most of the power. without it the battery should last hours.
oh, last thing. a clipped signal uses a hell of a lot more current. and with all the boost settings you are using... full volume... ya, you ARE clipping the shit out of it.
Edited by skittlesRgood
Posted (edited)
the way i usually run the radio is with the bass boost off. bass set to -7 and treble set to 4 with volume 42. i think it is like a 165 amp battery. and it plays for like 30 minutes or so. i have seen other radios on you-tube that have amps in them that can play for a few hours. and yes before the amp i played the radio for like a week of riding before the battery went dead.oh lastly i'm not running the battery completely dead. it starts at about 12.4 volts then after 30 mins or so it drops down to 11. something volts and then radio and amp shuts off
Edited by bass_stalker
might wanna run a charger on the batt aswell so itll play longer....just a tip yaknow
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
well the problem is i use it on the four wheeler that's why i play it so loud. so that's why i cant run a charger on it. another option i was considering was buying a second battery then running it in parallel would that double the amount of time i can play it for?.
lol ya, that would be running the battery dead. you are really hurting the battery by running it so low. its probably already lost a lot of its capacity. a deep cycle battery will last longer (amount of charges).
yes a second battery will obviously let you play longer.
see i thought when you ran it dead you dropped it to like 8 volts or so.
