ya, if your running the battery dead each time i would say a optima yellow top since its a deep cycle. but your going to kill any battery if you do that. looks like you have room for a G31 battery. should last a while longer. obviously that amp is whats using up most of the power. without it the battery should last hours.
oh, last thing. a clipped signal uses a hell of a lot more current. and with all the boost settings you are using... full volume... ya, you ARE clipping the shit out of it.
geezus people stop suggesting those over priced shit-cell batteries.
OP: look for higher AMP HOUR ratings and COLD CRANKING AMPS. these 2 numbers in conjunction will give you your longevity of use between charges. Get an AGM (Abosorbed Glass Matte) battery, they're great applications like this as well as in the cabin of vehicles. >> take a look at the deka intimdator on remybatteries.com i think they're 189 plus shipping for 100AH and something like 800 CCA.
Just get some deep cycle wet cell batteries as they can take being discharged near dead and come back full vs. an optima or other type of battery like an agm. Naturally the bigger the battery the longer life it will have and if you double up and use 2 you will get more time to play with them.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
ok thanks for all the advice and answers. i learned a bit and i'm gonna look at a few different batteries
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
