Maroon97SL Posted October 11, 2010 Report Share Posted October 11, 2010 (edited) Lately my lights have been dimming bad when stopped at a stop sign, stop light etc. When im driving my lights are fine. I didn't think a RF prime 500-1 could make my lights dim this bad, but it wasn't always like this. Do i need to get a new alternator and put a second battery in my car? do i have a bad ground on my amp? should i do the big 3? Edited October 11, 2010 by Maroon97SL Quote 2000 White Saturn SL2 Kenwood KDC-248U Head Unit 1 Rockrod Fosgate HX2 punch DVC 12 1 Rockford Fosgate R500-1 amp Stock Mids & Highs. Budget Build, I spent about 330$ for the setup. but its a crx, if you cant fart and do a 150 in a crx there is something wrong... Link to comment Share on other sites More sharing options...
Guest Posted October 11, 2010 Report Share Posted October 11, 2010 alternator cant output enough current to keep everything happy. hence the voltage drop. stop playing full tilt at stop signs or get hid's. a free option and a paying option Quote Link to comment Share on other sites More sharing options...
EclipseChris Posted October 11, 2010 Report Share Posted October 11, 2010 This is a waste of a thread. There is something called the "search button" and its a wondrous thing. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback. Link to comment Share on other sites More sharing options...
moetpoppin Posted October 11, 2010 Report Share Posted October 11, 2010 you need atleast 4 batteries and 3 HO alts to fix this problem man.... but yes, start off doing the big 3 if youre concerned Quote TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
Bumpin the TWP Posted October 12, 2010 Report Share Posted October 12, 2010 you need atleast 4 batteries and 3 HO alts to fix this problem man.... but yes, start off doing the big 3 if youre concerned with just a RF prime 500-1 you can easly run off a stock alt. just get another battery, for just that you would be fine with your stick bat and maybe a Kinetic HC600 Quote 2x Sundown Audio SA-15's nuff said for my little old car 1999 Plymouth Breeze Build Log Link to comment Share on other sites More sharing options...
MrSkippyJ Posted October 12, 2010 Report Share Posted October 12, 2010 sounds like your alt is going bad, just get it tested and if it is bad, get a stock replacement. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Guest Posted October 12, 2010 Report Share Posted October 12, 2010 how about this. best fucking solution ever, and its free and requires almost no work. lower the volume when stopping. Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted October 12, 2010 Report Share Posted October 12, 2010 how about this. best fucking solution ever, and its free and requires almost no work. lower the volume when stopping. except he said it hasn't always happened. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Guest Posted October 12, 2010 Report Share Posted October 12, 2010 could be a loose connection. check all connections before doing all that work in taking out the alt and taking it to a store. Quote Link to comment Share on other sites More sharing options...
Alex K Posted October 12, 2010 Report Share Posted October 12, 2010 (edited) could be a loose connection. check all connections before doing all that work in taking out the alt and taking it to a store. Yup. My alt + bolt came loose and was sparking on the run of 1/0 to the bat. I kept wondering why my voltage would go into the 10's every now and then, and then saw it one night when I opened the hood. tightened that back down and voltage went back to 14.5. Edited October 12, 2010 by Alex K Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
