DC Sound Lab
Well I just fixed the stripped threads on my motor and took apart my sub and got some bigger bolts to hopefully hold the motor on a little better this time :) anyways I got the cone and spiders off and used acetone to get the remaining glue and surround off of the top of the basket. Now the spider landing is solid as a rock. I have managed to chisel away and pry most of it away with a plier, but there is still a 4-5mm layer of solid rock hard glue/spider on the spider landing. Have any of you guys ran into this? Can I just glue the spider over this? How much is a new basket from DC? If you have to pm me that I would appreciate it, because at this point I might have to get a new basket... Thanks in advance.
2010-11 Project:
1 15" DC XL
1 AP3k
1 3.5 cube interchangeable port box
Finishing this all up over the winter and will be starting to compete in 2011!
651 - 612
8 0 grit flap disk on a grinder will take that off nicely. no need for a new basket just because of glue. keep grinding until you see silver.
and no, you cant glue over the old glue.
Edited by skittlesRgood
On both of my recones I used a wire-brush attachment on my power drill. Time consuming, but I had to improvise. :/
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
wateva tools that works for you is what id use i use a dremel vibrating slash cutting sanding tool, wire wheel, hammer chisel, sanding disk, etc.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i used a chisel and a flathead screwdriver and popped it from the top to break it loose then started going around the spider landing. the little bit left over i just sanded with my dremel
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
Exactly what I have used. Takes a little time. But i'd rather take my time than leave any residue.
Yes I agree. Now the recone should come with the coil spiders and cone pre-glued correct? I was quoted $XXX shipped for the recone, that seemed spendy to me but i've never bought a recone before? Any anyone know how much a new basket is just out of curiousity?
Edited by dj00140
2010-11 Project:
1 15" DC XL
1 AP3k
651 - 612
Take down the recone price. They like top keep it hush. And correct. You will get the cone, coil, and surround assembled. Just gotta center the coil in the gap, glue, then glue the dustcap. Solder leads. Not too bad.
  • Who's Online   0 Members, 0 Anonymous, 3489 Guests (See full list)
