Why is the Audioque Clipping?
Got a Audioque 1200d pushing 2 re audio sex12d4 and it sounds like shit. Everytime it barely gets loud the amp starts clipping and the protect light comes on. I dont know wat to do. i wont to send the amp back cuz ive gotten three shop opinions and they all say the amp is not even pushing the watts that audioque claims. should i try to send it back or is there somethen else?
What is your electrical like?
Also check you RCA preouts at the headunit. Then check it down the line. Make sure you are getting the same reading.
are those subs connected properly down to 1ohm? you might want to double check.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
user error likely
lots of problems
wheres the gain at, headunit settings, what are the subs wired to, what are you playing, how did u set gain
turn all the amp settings down, make the ssf little below half, gain about half, bass boost at 0 and lpf around 80hz if you can, sound better?
and that shop is wrong, those amps put out way more than what they say when used correctly, tell them to STFU, its either the subs or the box or the way you have it tuned.
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Got a Audioque 1200d pushing 2 re audio sex12d4 and it sounds like shit. Everytime it barely gets loud the amp starts clipping and the protect light comes on. I dont know wat to do. i wont to send the amp back cuz ive gotten three shop opinions and they all say the amp is not even pushing the watts that audioque claims.should i try to send it back or is there somethen else?
sales BS.. they tryin to get you to buy their shit. you know what you bought bro... heard only good things about AQ.
i used to run the aq1200d, yes the clip indicator on the knob IS sensative, its only bad clip when its a solid signal
its 100% user error IMO in this situation, kids prolly got everything jacked for distortion
Team Sundown Audio
Your obviously doing something wrong, I have the same amp and it is getting 14-13.8vs. Turn the bass boost on the amp all the way down to zero set your LPF at 80-100 make sure you subsonic filter is at or a little below your box tuning. Check your headunits settings to make sure that the bass boost is all the way down or off. Go to your pre -outs and turn the subwoofer level all the way up or on. Then play a song with lots of bass ( i put on) and keep the clipping light handy. Start your gain off at lowest and work your way up till the clipping light comes on and back down the gain till it stops. If your still having clipping then your amp is fucked, return it get a new one
See i thought the same thing i stressed over what to buy for so long and i was so happy till it started to clip and the shop i went to today seriesed the wires at the amp. i dont know as much as i should about car audio i just know my shit should hit harder than it does
  • Who's Online   0 Members, 0 Anonymous, 583 Guests (See full list)
