Carroot1 Posted October 15, 2010 Report Posted October 15, 2010 wire you subs like this, one sub has 2 positives and 2 negatives wire 2 positives together and then 2 negatives together. On the other sub do the same. No you should have 2 postives and 2 negatives, wire those together so you should have 1 positive and 1 negative. Take the negative and connect it to the amp and do the same with the positive.
99hoe Posted October 15, 2010 Author Report Posted October 15, 2010 So you only use two of the terminals on the amp?
BeAlLsTaR13 Posted October 15, 2010 Report Posted October 15, 2010 So you only use two of the terminals on the amp? yes, they are wired in parallel inside the amp, just wire to one set of terminals to avoid even more confusion. Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
99hoe Posted October 15, 2010 Author Report Posted October 15, 2010 Right now there is a positve in one terminal and the negative in one and then the other posative and negative are in a connector together. so i should pull those apart and twist the positve together in one terminal and the negativ etogether on one terminal and leave the othe two empty? Right?
Robert8252 Posted October 15, 2010 Report Posted October 15, 2010 All positives need to go STRAIGHT to the amp and ALL negatives STRAIGHT to the amp. If you connect all te positives together inside the box that is fine as long as no positive touches a negative. Hope that makes sense. Your Subs are wired around 4ohms right now so you're only getting like 500 watts out of the amp 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Robert8252 Posted October 15, 2010 Report Posted October 15, 2010 What I meant by inside the box is you could have one terminal on the box and all 4 postings can go to one wire to the amp. Same with the negatives. Let me bust out my very expensive photo editing equipment and make you a pic. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Robert8252 Posted October 15, 2010 Report Posted October 15, 2010 Oh yeah. Try to keep all your wires about he same length from terminal to terminal. Helps not build up resistance. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Carroot1 Posted October 15, 2010 Report Posted October 15, 2010 Oh yeah. Try to keep all your wires about he same length from terminal to terminal. Helps not build up resistance. hey i have the same amp and set up. I wired all the positives together and they only use 1 slot on the amp same with negatives is that ok?
99hoe Posted October 15, 2010 Author Report Posted October 15, 2010 Haha thats awesome see i thought you put both positive in one terminal and both neagative in another
Robert8252 Posted October 15, 2010 Report Posted October 15, 2010 It doesn't matter. Take that same drawing you could have one terminal on the box and all positives to one and negatives to one. And just run one wire to one positive and one one negative and it will see the same impendance. Even though it shows you two terminals on the amp they are actually just one big positive and one big negative. It's to make it easier for you if your using bigger speaker wire each speaker could have it's own terminal instead of cramming two big wires into one. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
