i got ahold of a adjustable voltage regulator for my jeep finally and a new agm rear battery. i was reading the label and said do not pass 14.6v when charging. but i need to set at 15v to keep up for the power of my amp. will i still be safe at 15v for 2 batteries
Team DBs (Driven By sound)
I don't think it would be safe to run 12volt batts that high.
You need 14volt batts.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
Who are a lot peeps? Lol. No one I know...lol
theres alot of peeps on here doin it even said on the battery 14.6 max charge
That's still .4volts under what you're trying to do.
And I didn't say you can't do it, I said it wouldn't be safe to do it. But as TeamHT said, Who are a lot of people? Do you have links to any build logs that shows that?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Guest DC Power Kyle
I charge my XS Power D2400 and D2700 battery at 15.1 daily for over a year with no problems. I think meade has his at 15.5? or 15.6
steve meade does 15.3 daily i basicly wanna sit at 14.4 full tilt so i figured if i set it at 15v and when the hard lines kik in i'll settle at 14.4
So you guys that charge these at 15+ volts for several hours like turning you d3100 into a d3400 or smaller, because you are aware you are forcing the gas out of the battery. Have fun replacing batteries every couple of years.
Edited by AMI CUSTOMS
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Perhaps you should do a little research then because you are wrong.
Here I will help you out, this is one of Optima's disclaimers all there batts are AGM's, XS power has a similar disclaimer but I can't find it anywhere
Always use a voltage regulated battery charger with limits set to the above ratings. Overcharging
can cause the safety valves to open and battery gases to escape, causing premature end of life.
These gases are flammable! You cannot replace water in sealed batteries that have been
overcharged. Any battery that becomes very hot while charging should be disconnected
immediately.
You can also run into the battery expanding or bulging out due to excessive overcharging due to the extreme heat that is created from prolonged overcharging.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 2696 Guests (See full list)
