If on the ohm setting on the DMM, I touch the probe to the OUTSIDE speaker terminals on the box, is that number the ohm load the amp is seeing? I have my dual 2 wired to 4 ohms, but when I touch the terminals it reads 1.5. Is it possible I blew a coil?
SMD Super Seller
My Feedback Thread
Dvc 2 ohm sub can be wired at 4 or 1 ohm. You obviously have it wired to 1 ohm.
2006 Nissan Z Track.
My Feedback Thread
take the woofer out and stick the probes in the speaker terminals. thats the only way to really know. its quite possible tho i have a woofer sitting in my room with one coil reading 2.0 and the other reading 3.8 lol <-meaning its donezo
Edit: Alex K's idea is possible too. although itd be weird for a woofer to have coils that would wire down to 1.5
Edited by Steph3n1
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
It could also be the hardware that you used for the bolts giving you the weird ohm load.
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
:orly3: Double and triple checked. Thats the screwy thing. I should point out the sub cut out on the way home from dinner. No smell, no smoke, cool dustcap. Then I check and get that reading. I'm gonna go pull the sub real quick.
SMD Super Seller
My Feedback Thread
Double post...damn phone. Lol
Edited by kbsmoker
if thats the case then the Vc could have partially un wound thats if it bottomed out. push on the cone somewhat hard if you hear a scratchy grinding noise then time for a recone!
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
yeah if it wont sit steady and keeps giving huge readings all over the place its shot
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
  • Who's Online   0 Members, 0 Anonymous, 746 Guests (See full list)
