I have an audiopipe amp that has one of the speaker terminals stripped. The screw part is fine, but the part it screws into is totally stripped. Is there any way it fix this? Could I get something larger to use as the screw part?
you could try to tap it. but it might not be deep enough.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
what exactly is tapping? on my saz1500 one is kinda like that..
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
It seems to be really soft metal that would tap very easy. Even after I did that wouldn't I need a bigger screw?
not necessarily...but tapping is an iffy thing to do. you gotta feel it out. if its stripped enough, yeah youd probably need a bigger screw, and youd need to tap in a slightly larger size to fit that screw.
tapping is when you can re-thread a stripped nut or screw with a unique bit.
get a 1/4" tap, tap it then go get a 1/4 bolt and be done with it... same thing happened to both of mine
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
