bad voltage drop
ok so im debating on getting a stinger 50 farad cap to go along with my sk-bt120 shuriken batt or do you think i should just get another batt to help keep higher voltage in my 96 tahoe??? current equipment is as fallows and alts are in the making
2-2100rms brz amps strapped / but only able to run one of them currently due to voltage dropping super low
1- sk-bt 120 shuriken 2600 amp batt
big 3 done
stock alt at this time
all tsunami 1/0 guage wiring
2- fully loaded Fi BTL 18s
20 cubic ft box tuned at 21hz
any suggestions??? could use the help A.S.A.P. please
Alt supplies power and batteries store it, if your dropping really low then you'll need a better alt to start off with and having a small bank of batteries to store enough capacity that voltage spikes don't occur from massive hard hits from the bass.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Batteries don't raise the initial (charging) voltage, they try to maintain it.
With all that power, get the biggest alt possible and upgrade the starter battery. If the charging voltage isn't what you want, get a voltage regulator from Mechman or MLA.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Ok I have plans to do a quad alt in the "HOE" here real soon any suggestions on where to get the brackets n such? Also is my stock alt really that crappy that it can't hardly run a 4200 watt amp or should I replace that alt as well?
try different grounding point on your big 3 or run a negative 0g from front to back. my hoes voltage will change with different grounding points and most definetly do 2 alternators if you can. i went 3 and its barely enough. a good high output alternator will make a huge difference. plus the hifonics amps are current hogs i had 1 2008 and it would drop with a 220 amp iraggi and 4 svr 3000 batterys
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
A quad alt for 4200wrms? Or do you plan on adding/upgrading amps, because that would be crazy if It were for your current system.
Try DC Power for the bracket. Don't expect it to come fast. Also ask Mechman. He may find a local Tahoe that he could test fit it in. You could look for local shops too.
The stock alt probably isn't shitty. It was just made to power your TRUCK, not a ton of extra shit that the average person wouldnt even consider buying
LMFAO so true
:blush:
Its what, a 140 amp alt? Give or take 50% of that is used to maintain function in all electrical applications that come stock with the car.
This gives you ~70 amps for charging and supplying, when your amplifiers are demanding 420 amps at max, give or take a little. When the alt cannot supply the demand asked, voltage will drop. When you're short 350 amps, yeah you might drop a ... Lot lol
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
:lol:
LMFAO so true
:blush:
Check out the forsale section, theres a quad alt setup for a tahoe forsell, or buy a single alt.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
not sure on your mounting setup for your year tahoe. no one makes a quad ,dom did a one off for lame dude jp,Dc only does a tripple for my year thats what i have. maybe mechman but all ive heard is hes doing doubles. most quads are for 2000 and up.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
