Need help with viper 5701 asap plz
Well i need help installing viper 5701 asap i was able to install everything else but cant get the remote start to work i am trying to install it on my 92 lincoln town car using this diagram http://www.directwholesale.net/diagrams/diagrams.asp?link=DW and the installation manual http://www.toyotatundraforum.com/pdf/Responder%20LE%20Model%205701%20Installation%20Manual.pdf but it wont start all i hear is clicking noises am i missing something well if some one could help i would really appriciate it
are the lights flashing? how many times. It comes from the factory in manual transmission mode.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
your parking lights on the vehicle. I bet they are flashing 7 times.
stand out in front of the car and watch the lights
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
ok ill be right back going to go check it out
well mayb i didnt set it up right because no light turn on but everything work doors lock trunk releases, horn goes off hood pin is in place
the new vipers come from the factory in manual transmission mode. you have to set it up for an auto transmission. Did you do that?
did you install a remote start bypass?
does your car need one?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Automatic Transmission Mode Programming
* NOTE: The “Automatic” option will need to be programmed ON to work with automatic transmissions, to do this follow the steps below. The default option “Manual” is a safety precaution that forces the installer to enable the Manual Transmission Mode (MTM) routine or program the unit to the “Automatic” option before the remote start can be activated for the first time.
1. Open car door.
2. Cycle ignition key ON then OFF. Do the next step within 10 seconds.
3. Press and hold valet switch until LED flashes 3 times (siren chirps 3 times), then release.
4. Press and release valet switch once then press and hold. Siren chirps once.
5. While still holding the valet switch, press UNLOCK button of transmitter. Siren chirps 2 times.
6. Release valet switch. Cycle ignition key ON then OFF.
i tried doing this but no luck ugh looks like i am going have to take it get installed :(
As n8ball said it is more than likely in manual transmission mode. Count exactly how many clicks you hear and post that...
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
