Octo port vs. T Line for Home Theater Use
OK so here is my dilemma...
I have some old subs layin around, one of them being a Logitech Z-2300. I want to get more out of it, so I'm gonna rip out the sub and plate amp, and build a new, much bigger box for it and put the amp in it as well. The only problem I have is deciding whether or not to build an octo port box or a t line box.
So what's your opinion on these boxes for home use, and which one would be better?
Thanks in advance!
-Alex
t-line
Hammerdown... 1%
t-line
Could you possibly explain why? I'm not trying to sound rude, I'd just like to know why a t line box would be better for home use than an octo port, even though octo ports are supposed to be so much louder.
build both out of particle board, see what you like, go with that.
i say tline tho, i personally had a kicker c8 in a tline at 41 hz for my computer, louder than my neighbors 15 ported, super responsive, and the sound quality was what really got me.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Alright man, thanks! Do you still have the plans for it, or at least know how big it was? I'm probably gonna end up tuning mine lower, but I'd like a general starting point. I'm a noob to building cabs.
bettery quality output. 41hz is a bit high tuning, but you could always face the port into a corner to bring your tuning down a bit extra if you have to. I'd shoot for 35hz maybe, but you gotta be a bit careful with the drivers that logitech used. They do ok as long as you dont beat them up.
octo-port is just a normal ported enclosure with a fancy looking port.
Hammerdown... 1%
why does it have to be octo port vs tline. all the octo port is is a ported box. and unless you just have to have an 8 or 10" diameter port your better off with just regular flared round ports.
since you want a home theater box you will want a low tuning. and with and flared round port you will most likely need either a very long port length or a very small port area. both of which make using that style port bad for ht boxes. but a smaller area can usually be gotten away with if its flared and if its lower power where port noise doesnt become too much of an issue.
My preference for ht boxes are tlines or passive radiator.
the downfall to some tlines though is that if you make them for ht builds you will need a long line length, and that makes them big. and most ppl dont ever properly build one, but rather just make a long line and pop a sub in.
passive radiators are by far the easiest way to do a ht box. its as easy to build as a sealed box, and you can have and extremely low tuning without having to worry about a super long port to deal with.
The type of octo port I would build would have a long port basically, which is what would make it louder. To the poster above you, its a Tang Band sub, and I've put it through hell pretty much every day. Back to you, I don't mind a big box, I actually prefer it, as it gives off a "I'm gonna rattle your teeth till it hurts" look. And yes, passive radiators are amazing. I own a pair of Klipsch Fortes, and man do they sound amazing. The reason I want to build a T-Line, is because I'm ripping apart my Z-2300 and putting the plate amp and sub in a new box, preferably much bigger that I can get much more out of my little 8" sub. I think I'm actually going to build an octo port using Sonotube, as it will be really cheap, and really loud. I'll be corner loading it as well, which should get even more out of it. I'm planning on building a T-Line for my Sony SA-W2500 sometime in the future, but that's a ways out there.
building an octo port with a sonotube is no longer and octo port, its just a round port.
the octo port name came out because some guy was too lazy to actually kerf the wood to make large round ports, and took the easy way out of just making an octagon shaped port.
Ohh... but it would be the same general concept of having a very long port and increased db's right? It's actually logically the same thing as a T-Line, just not folded, which makes it sound better and more efficient. Look up the legend of El Pipe-o. I'd be doing something like that, only smaller scale.
