55437Audio Posted November 4, 2010 Report Posted November 4, 2010 Ive herd that you cant use the Regular Acid battery's in Parallel with AGM batterys, Maybe its Bull shit to get you to buy there AGM battery? I will be putting 3 D3100 in the back and I have 2 of your every day acid battery's up front, Running both Pos and Neg off of the Primary for power to the Rear AGM Battery's.. This fine? or do I absolutely need all to be AGM Thanks, Austin My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
Skullz Posted November 4, 2010 Report Posted November 4, 2010 I do it and i'm sure others have as well with no problems. You'll be fine. EDIT: just make sure both batteries are fully charged before connecting them. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
55437Audio Posted November 4, 2010 Author Report Posted November 4, 2010 make sure all battery's are full charged or just the 2 up front.. My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
zachfowler222 Posted November 4, 2010 Report Posted November 4, 2010 i do and have no problems....and just charge every batt. I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
