osamio Posted November 8, 2010 Report Posted November 8, 2010 My trunk is set up with two twelves at the front of the trunk facing the rear of the car, then a 8-9 inch gap between the face of the subs, then a non-airtight divider ( if u look at the pic it's the chevy emblem part), then on the other side of that, the amps and caps. The divider is just that, a divider, and purely aesthetic, and by no means airtight, but could it is obstructing the waves from the subs from hitting the trunk directly, would this cause a major difference in sound quality? or loudness? 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Emoxihax Posted November 8, 2010 Report Posted November 8, 2010 subs shoulda been closer to the trunk imo 2004 Volkswagen GLI 1 10" Skar VVX ^^^ Looking for an amp to run it, Pm me if you have one ^^^
Baydestrian Posted November 8, 2010 Report Posted November 8, 2010 just a question...what's the point of that 3rd sub facing up? Is the box ported or sealed? looks sealed or are those ports on each side of the subs. 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
osamio Posted November 8, 2010 Author Report Posted November 8, 2010 just a question...what's the point of that 3rd sub facing up? Is the box ported or sealed? looks sealed or are those ports on each side of the subs. No point really. And it's two separate chambers for each sub. The boxes are ported on either side. 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
