The black wire is grounded in the engine compartment, the blue and yellow wire are both on the orange wire with blue stripe and the pink wire has been to a ignition turn on, and constant turn on..nothin works
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
your in the same boat i was.I bought a dual alt set up from mla for my 2007 chevy avalanche i only had 1 alt at that time and was waiting for my second alt to get to me.I couldn't get th mla module to work until i hooked up the second alt then it worked fine.You have to have both alts hooked up for the circuit to complete and for the voltage to increase.I went from 14.4 volts to 15.8 volts with the module hooked up.
  • Who's Online   1 Member, 0 Anonymous, 1575 Guests (See full list)
