uhoh_45 Posted November 10, 2010 Report Share Posted November 10, 2010 (edited) my buddy has a 1990 2.0l turbo- plymouth laser (sister cars to the Eagle Talon and Mitsubishi Eclipse) well i was wondering if you had anything that would work with this vehicles Edited November 10, 2010 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options... 35 4.1k
MECHMAN Posted November 10, 2010 Report Share Posted November 10, 2010 Yup, we have a direct bolt in 220 amp large case conversion unit for $449. It has great output at idle, and is totally bomb-proof for daily abuse. We can also add the voltage boost module for $50 if you like. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options... 546 3k 6
