ok heres some dimensions i drew up for a box im going to build for a friend of mine for one L7 15"
Using 3/4 MDF
Internal dimensions
L- 21"
W- 20"
H- 21"
Outer dimensions
L- 22.5"
W- 21.5"
H- 22.5"
Port
L- 14"
W- 3"
H- 12"
with my calculations it seems to be 4.6525 cubic feet after port and sub disp. tuned around 32 hz
this sound right to yal? thanks :drinks:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
There really isn't enough port area there. I'd do at the very least 50 square inches of port area. I have mucho experience with l5's and l7's and I know they like a lot of port
also, your plans put you closer to 29hz than 32
816-591-6592
www.kcrimshop.com
How Many square inches do I have there??
What should I do with the port? Make it longer wider or taller?
I'm just now learning how to make a box and tune it so
It's kinda complicated :/
Right now you have 36. I would make the port 5 inches wide and 25 inches in length
816-591-6592
www.kcrimshop.com
How tall would you make it though?
I wanted to put the port along the bottom of the box under the sub?
And what would that put my tuning at?
Edit: ok how bout the port 5 inches high
12 inches wide and 25 inches long?
That's 60 square inches of port right?
What would the tuning be?
Around 32hz?
Edited by RickyFriery97
For one L7 15, I would do 8 0 sq inches of port MAX, unless you aren't going to put shit on it for power. That sub needs between 5-6 cubes to get LOUD.
Edited by AMI CUSTOMS
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
The sub will be ran at 2 ohms on a hifonics amp I can't remember witch one though
Those dimensions put it right under 5 cubes
It's going in a trunk too
ok i was just with my friend and i was measured out his trunk and it was alot smaller then i thought...
my dimensions i have now are
outer dimensions
L- 16"
W- 30"
H- 16
comes out to 3.46766 cubes internal
any bigger and ill have to build it in the trunk and im not doing that..
not much room to play with and i want it ported
sub will be ran at two ohms on a hifonics brutus BRZ 2100.1D with specs are 1400watts at 2 ohm but the car is all stock electrical so it probally will be seein barley more then 1000watts
i want it ported with a slot port tuned no higher then 36hz
i was thinkin a port 10 inches wide and 5 inches high but how long??
sub facing towards the seats and port firing driver side
internal width is 28.5 inches
any help is appreciated :drinks:
im still confused with tuning boxes but im getting there :pardon:
outer dimensions
L- 16"
W- 30"
H- 16
If you have that little room for your L7, I recommend selling it and getting something that requires more like 4 cubic feet max instead of 6! I have one L5 in my truck in a 6 cubic foot box, and it SLAMS, check out my video if you want to. But the one thing I know about kickers is that they love their space. A single L7 in a 3 cubic foot box (ported) on about 1500 watts would get owned by a single L7 in a 6 cubic foot box on 950 watts... You will be disappointed if you decide to build such a small box for your sub.
With those figures, 26 long for 36 hz and 30 long for 34, but with a port that long that is going to take away more net and make the box even way smaller. Cuz at 36 hz tuning you are at a 1.0 cube worth of port, so that brings your net cubes down to 2.4 without the sub. WAY too small, you would need a shit load of power to make it do anything. You should consider either selling the sub or making a sealed box that is 3.4 cubes.
Evo X build log
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
