WEll i have a 95 chevy caprice. the temp gauge is going nuts.. 99% of the time it'll seem off and stay at 0 degrees. every once in awhile it'll kick all the way to the red "HOT" and my dash has a light that says "check gauge"... i crank the heat to see if its really really hot.. "it isn't" then it'll randomly turn off.. no harm.. NOW i just want it fixed. I already replace the temp sensor "like a brass lookin spark plug" but it didn't fix it... any ideas ??
If i had to guess I would say it's something with the actual gauge possibly going bad, and if it pegs out your check gauge light may just come on automatically because of this.
Sounds like the stepper motor in the gauge is going bad. I had 2 of my 4 go out on my 01 Impala , was a pain to fix em..
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
well when i crank the car "and you know where the gauges so all the way across the board before starting ??" it'll work doing that.. just doesn't read temperature
