so Ive had my XL 15" for a few weeks now, it sounds good but i just feel like it could be a lot louder i have my aq2200 set at 2000 watts right now (44.7 volts @ 1ohm if i did my math right) and my sub hardly moves at all im not sure what to do get some batt bank and see if that helps my clipping so i can turn it up louder or does it call for more POWA?
Pioneer MVH-P8200 Hu
Dc Lvl 4XL 15"
AudioQue 2200 sold
Knu wire 1/0 ultra fleks & Krystal Kable Rca
Stock alt
Stock battery up front
Xs S3400 in back sold
your trunk lid is going to get molested like a drunk stripper at an orgy.
What kind of vehicle? Any type of electrical upgrades at all?
The XL can take more but an AQ2200 should be nice. Box specs? Also, if the sub is still new its going to be pretty stiff.
Sounds to me like it isn't set right, 44 volts ac would be likily around 20 amp so that is only ~900 watts real power, bump it up some.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
from reading your signature, you only have a stock battery? im guessing you have some massive voltage drop... i run a stock 96amp alt with a kinetik hc1400 under the hood and a hc2000 in the trunk and drop into the low 12's at idle but it stays above 13volts on the highway.. normally around 13.4 at full tilt...
ive got some decent battery power but if your running just the stock battery then ill bet your voltage is dipping down below 12volts quite easily...
voltage drop will make the amp clipp... meaning less clean power... i keep a close eye on the clip light on the bass knob... light flickering is Fine... but if its lighting up then you need to back off of it a little
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
upgrade your electrical, then i would turn her up a little more...i have mine set up to i can have some flickering on the clip light and she will blast ALL day (well i have the AQ 3500s) but don't let her sit on the solid red...especially w no electrical upgrades...i honestly wouldn't play it UNTIL you AT LEAST change the battery under the hood. your risking the amp and the sub
NoFearX18 said:
trainman0978 said:
oh shit...i just read...me and Rogers said the same thing hahaha
02 accord lx no electrical upgrades yet just a beefy 0ga ground from the stock batt, box is 3.5 cubes at 35Hz
hmm not sure i thought i read on here that was right, and if i used a 45hz test tone to set the amp with a dmm i had to turn up the lpf so would i turn my lowpass back down after its set
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
im planning on at least getting a D3100 in the next couple days
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
Kind of overkill but do the big 3 also. Very important.
No, he is right watts = Volt Squared divided by ohms.
44.7 * 44.7 / 1 = 1998.09
http://n2caraudio.com/forum/index.php?topic=16.0
Might want check you dc resistance with a vom to make sure it at 1 ohm. Cause if its at 2 ohms or more your cutting your power in half.
n2caraudio.com
  • Who's Online   0 Members, 0 Anonymous, 728 Guests (See full list)
