DC Sound Lab
(4) 12"DC Audio Lvl 4 Which Amp
1 2200. Absolutely. Voltage probably wouldnt budge. But two. Or one 3500. You'll definately have a huge voltage drop. Since all your power would be coming from the batteries very quickly.
Edited by Robert8252
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Read the specs people. The AQ3500 is rated 4300rms@1ohm and are definately under rated. If your voltage stays up they'll easily do 5k. There a few members here who have proven that
damn guess i should of read ll was thinkin they did 3500 or a lil more but id rather have more power than less lol team mate was running 3 of the 3500.1s on 3 BTL 18s and he loved them amps. thats some good power for the price for sheezy
My old setup was 4 12" Rockford Fosgate T1 subs and 2 RF 1500-1BD amps @ 1 ohm and it handled that with no problems.
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
All depends on install. Could you install a 3500 and get by with what you have? Yeah. Likely you wouldn't be getting anywhere near rms of the amp. Minimum. Get another battery and give it a shot. But leave budget for another battery to be safe.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Yea cause Michael at Audioque said i could power the AQ3500.1 no problem with my Kinetik 1800 & 2000.
2011 Subaru WRX
In the works:
The guy Loudnlow on here is running a 3500 and has a "similar" electrical. Pm him and ask what he's running. Ok not sure on alt but between 160-260 iraggi, and two batts in the back. Not sure what ones. And I think one run of 0g + and - front to back. His works but he also has had problems off and on. Never dedicated the problem being electrical but it's what I think it is.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
I think its gonna do fine. It draws less current than the 2 1500-1bd. Anyone else have an opinion on my question?
2011 Subaru WRX
In the works:
you have to remember box rise im only getting half my power to my xls
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
What do you guys suggest I do to power these bad boys? (2) AQ2200 OR AQ3500 or does anyone suggest a different amp that will power these and work with my setup.
2011 Subaru WRX
In the works:
  • Who's Online   1 Member, 0 Anonymous, 648 Guests (See full list)
